Eliminating VSS Top Speed of 110mph???
Old 10-03-2006, 07:08 PM
streetsmoker's Avatar
I'm needing to know if there is a way to get rid of the top speed limiter cheaply without spending $120+ for BD's unit? Or something similiar. Free would be great!!!!
Old 10-03-2006, 07:48 PM
Ramirezh's Avatar
$120? That's a better deal than I got.
Old 10-03-2006, 08:59 PM
Yeh, thats for a used one and I know they only get expensive from there. I thought I read somewhere that you can just cut and splice a switch in one of the wires, but search function here turned up nada, zip, zilch.
Old 10-03-2006, 09:45 PM
BigDan's Avatar
I shot Bob Wagner a PM a few weeks ago about a Smarty program that would eleminate the top speed and he said Marco is "working on it"
I hope Bob or Marco gives us more info....
Old 10-03-2006, 10:33 PM
abc4yew's Avatar
With the '03 you need the RAD with speed unlimiter. Even with Smarty my times were .3 to .5 seconds faster with RAD on...but you loose the stock gauges including RPM's unless you have a manual RPM gauge. ks
Old 10-03-2006, 10:52 PM
acook's Avatar
What about just jacking with the speedo? Saying you have smaller tires then you do, would that work?
Old 10-03-2006, 10:55 PM
Dan Marino's Avatar
I turned mine back on the other day in a pull and I hit 3670 RPM on the attitude monitor. The best RPM I ever got W/O it was 3550. What is your highest RPM?
Old 10-03-2006, 11:01 PM
abc4yew's Avatar
Dan, I never checked RPM to see what it was at Maximum...With Smarty and RAD off I've drifted almost to 3600. On the track I never get to normal max speed of 122mph which is 3500rpm's. ks
Old 10-03-2006, 11:03 PM
CG98x's Avatar
The diabo raises the rev limiter to 3650 it seems. I never saw above 3525 on my attitude before but since the diablo I see around 3670 when I check the records now. I can't believe you lose all the stock gauges with the RAd, by turning the key to start you only lose the speedometer.
Old 10-04-2006, 06:22 AM
abc4yew's Avatar
You lose the speedlimiter all the time with the gauges all working...you only lose the gauges when you turn the Torque Mangement off which is only for racing....and I have a computer controlled tranny so I know exactly when my tranny is shifting when racing. ks
Old 10-04-2006, 07:31 AM
Dan Marino's Avatar
Mine didnt. It would hit the rev limiter hard. Popping all the way down the pull track. At the end I would check max RPM and the highest I hit was 3550 and most of the time it was 3450 or so. The other day when I flipped the Rad on it never hit the rev limiter once.
Something interesting is the differences all our trucks have between them. Along with boxes, downloaders ect. there are many differences in levels of performance. I swear I think you could take the same two trucks, right down to the paint put on the same boxes and the same driver and the two different trucks would run different.
Old 10-04-2006, 11:05 AM
lit up's Avatar
Go to the BD website and download the instruction for the eliminator. It will show you which wire to cut to splice in thier box. (I believe it is green with a yellow trace). Just put an on/off switch in place of the BD box and it will shut the speedo completely off and on 325's you can hit 118 on stock RPM's. If you use the BLCL, it will raise the RPM's to 3500 and your top speed will be 128.6 mph. Both speeds recorded via GPS.
Old 10-04-2006, 11:51 AM
BigDan's Avatar
On my 03 I can take it to 3500rpm in all gears except for 6th which hits the speed limiter at a 108 as read on the speedo but actually going faster since I have 35's.
I think the computer defuels based on the speedo not rpms in 6th gear. The 3500 rpm doesnt bother me because that would mean 138 mph with 3.73's and 35's.
Old 10-04-2006, 04:22 PM
qwert's Avatar
If you just unplug the ABS harness it will do the same thing and then you can just plug it back in, this way you don't have to cut any wires.You still lose your spedo and gauges.
Old 10-04-2006, 05:37 PM
DTR Advertiser
kantdrive55's Avatar
That will only work 98.5-2000.
Quick Reply: Eliminating VSS Top Speed of 110mph???
