Electronic wastegate ??
Trying to fit a 2nd gen Turbo (66mm) on a 06 cummins!
how do you make the electronic wastegate work with this turbo?
Sorry dont treally understand this...
we are also going to run a smarty, F-2 inj etc...
madhat's monkey boy...
You arent going to make it work with the OEM wastegate controller. You can put a dummy sensor in and just use a mechanical wastegate or the boost elbow that is probably on the aftermarket turbo now. You can just use the smarty to turn off the boost control and use the elbow. There is a posting somewhere telling you how to make the dummy sensor or you can buy one from II for 25$ or HTT
i left the electronic w/g solonoid plugged in, in a bag,
i am getting overboost code, at only 38 psi boost. what should i do? does the samarty wastegate option have to do with this? or should i try the resistor?
I know it may sound silly, but are you reloading the SW after you make the change on the Smarty? Other than that, I dont know what to tell you. I have the original solenoid hooked up and have run 60+ PSI with no overboost codes.(my intercooler did throw a overboost code though ) The wastegate setting on the Smarty is supposed to allow you to run as much boost as you can make.
drewblood
04-15-2007 08:53 AM
SmokinDodge12V
34
07-13-2006 11:11 AM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
