Electronic transfer case heated seats relocation for cubby hole gauges
I wanted to mount 3 gauges in my 3rd gen but didn't want to loose my grab handle. I didn't like the dash mount or steering pod option either. So I decided on the Autometer 3 gauge cubby hole mount. The only problem there is I have a Laramie so I have the electronic transfer case switch and the heated seat switches.
So I decided to relocate the electronic transfer case controller and the switches for the heated seats. I decided if I was going to move things around anyway I would move the HVAC controls down and mount the gauges in the middle below the radio.
The first order of business was enlarging the lower opening to fit the HVAC controls. The HVAC controls are slightly larger than the cubby hole opening on the bottom. I had to enlarge the opening by 1/8-1/16 mostly on the bottom.
Next I installed the gauges into the Autometer gauge pod. I have Dipricol gauges so I had to work on the braces that hold the gauge pod to the center console of the truck. Autometer gauges mount on top and bottom and the Dipricol gauges mount on the sides. So I used some L shaped corner braces I bought at the hardware store and cut/bent/drilled them to fit. This part was pretty time consuming because the tolerances are close since the gauge pod was designed to fit the smaller lower hole.
I next embarked upon cutting the dash to fit the Electronic transfer case and seat controls. I cut the Laramie panel where the drivers heated seat switch had been. I then cut the dash where the cigarette lighter had been and epoxied the electronic transfer case in place. To get this to fit I had to also cut out a portion of the dash for clearance behind the control.
I then cut out for the heated seat controls to the left and right of the newly relocated HVAC controls. I expoxied them in place also.
I didn’t have to cut or splice any wires but the electronic transfer case was pretty snug. Make sure you mark the proper wires for the heated seats as well as the switches because the switches are designed to go with the corresponding wires.
Pics are in my gallery
And I get nervous just drilling a single hole Can't wait til the pic's are posted. Did you check out the roof mount gauges? I just saw them in another post, I like that idea, much easier than what you went through.
Oh believe me I was very nervous. I bought an extra dash console off Ebay before I started. So theroretically if I bought a new transfer case/heated seat panel I could return it to normal.
Hopefully the pics will be approved soon. It turned out pretty well.
You said you had to enlarge the lower hole.
What about the upper hole, wasn't it a little too large for the pod that was built to fit in the lower hole?
Great looking installation by the way.
The reason I didn't go with the cubby hole mount, the gauges are too low. Too far away from the other instruments. The new overhead windshield mount has the same problem. You have to take youe eyes off the road to see the gauges. I really like your idea though. I wish I had done mine like that. (I used the duel steering column mount, and the SRT-10 pillar)
Just checked out pics in gallery,
That is a Sweet install, it looks stock!!, you can tell you took your time and did an excellent job, congrats on a truly custom interior and a great idea (I should have known you were from VA)
MikeyB
13
06-26-2012 08:16 PM
tool
04-21-2005 07:27 PM
ATVConnection
10-28-2004 07:20 PM
Truckjerk
08-13-2004 01:14 PM
ATVConnection
03-04-2004 02:58 PM
