Electrical Guru's need help!!!
Allright got my guages in and they work!!!!
Only thing is that they stay lighted even when the ignition is on not just off the dimmer switch which did I cross???
Thanks SHane
P.S. I'm leavin for dinner be back later...
Thanks SHane
Hook the guage lights to the ashtray light. It is controlled with the dimmer and is only on when the lights are on.
What did you have for dinner? Did you bring us all desert?
By the way... I just got the Fuel pressure kit for the commander and when you remove the bolt out of the system does the bolt and line hook back up? or is it just a dummy kit?? Do you follow?? The pic's in the kit I got aren't that great so I am just confused on what to do with all of that after I get the banjo bolt and filter on?
Thanks Quad
Shane
dizzel
07-31-2009 07:54 PM
