Egt's when pulling
Old 10-27-2007 | 03:41 PM
big_bear_92007's Avatar
Egt's when pulling
what are normal egts when pulling a travel trailer or any trailer really?
Old 10-27-2007 | 03:45 PM
gscmiller's Avatar
Ive never seen over 1200 when pulling up hill @ wot. I stay between 900-1000 when pulling heavy. My kind of heavy is 12-13k.
Old 10-27-2007 | 04:32 PM
BlackSunShyne's Avatar
With your mods, and depeding upon what the weight and the aerodynomics of the object you are pulling, you will see anywhere from 600 (in the flats) up to 1200-1250 on the up hill pulls. If you see above 1250 don't keep it there for an extended period of time.
Old 10-27-2007 | 11:42 PM
ok i am goin to be pulling a travel trailer from nac to kerrville which is bout 300 miles and im gonna have a rhino in the bed of the truck .... i pulled the trailer the other day and my egts where around 700 when i wasnt accelerating and was doin 70
Old 10-28-2007 | 10:00 AM
Luvnacumns's Avatar
is that pre or post turbo?? Pulling my 30 foot trailer that weights 14k or so doing 75-80 on the freeway I run around 1100 degrees but I have twins so that will help cool too!!!
Old 10-28-2007 | 11:05 AM
fordracing19's Avatar
I was wondering the same thing. Just drove from Tx to Pa to pick up a car. Egt was 1050 max in the mountains with the diablo tow tune.
Old 10-28-2007 | 11:53 AM
Equalizer 2's Avatar
My truck is stock with a boost and pyro only.
I pull a 10,000 lb 5th wheel and pull some good grades. Running on the flat at about 60 mph I see about 700*-800*. When I hit grades I generally try to maintain the 58-60 mph but when I see the EGTs start moving up to about 1250* I back out of the throttle to get the EGTs to drop to about 1200*.
Just what I do, you may do it differently.
Old 10-28-2007 | 01:31 PM
NB64's Avatar
You can easily run a stock truck up near 1350 while towing, especially while climbing a steep hill. I've had gauges long before I had a module. Once I used quads standard box the egts seem to be lower. I think it is because of the extra power and not needing to push down so hard on the pedal. On flats usually around 1000 degrees.
Old 10-28-2007 | 02:29 PM
JuzPlaneKrazy's Avatar
When I ran stock pulling 8-9K lbs up 6-7% grades I would see 1200-1300* to keep it at 55mph, thats with a auto trans and 3.73 gearing.
Now running with the XZT 65hp tow chip and pulling 15,000lbs up the same grades I can maintain 45-50mph and stay around 1100-1200*. Without the chip I was barely able to maintain 35-40mph and saw EGT's pushing 1300-1400*.
I think once you start pulling over 11,000lbs you better have some kind of help with power/temp managment.
Old 10-28-2007 | 06:21 PM
bighornram's Avatar
I always hear you can maintain 1350 steadily climbing a hill while towing etc. without any worries. Higher than that won't hurt any thing as long as its only a couple seconds.
Old 10-28-2007 | 06:33 PM
doznfire's Avatar
My truck without the smarty on it towing my fiver back from vegas I could hit 1500* on a long pull. My trailer weighs 16,000lbs.
Old 10-28-2007 | 07:02 PM
wardy70's Avatar
I just made a trip with two SUVs in a 48ft enclosed coming up Jellico Mt. in Tn, I set the cruise at 65 and the egts were right at 1350
Old 10-28-2007 | 07:04 PM
cameroneod's Avatar
The faster I go, the lower my egt's get.
Canuckville
10-18-2009 10:43 AM
choppers555
25
04-14-2009 02:21 PM
sallyman1
16
07-04-2008 05:21 AM
mullercarl
Competition / Pulls / OffRoad
45
03-19-2007 10:10 AM
roberts11260
12-18-2006 10:55 PM
Quick Reply: Egt's when pulling
