egts get hot fast
egts get hot fast
i have a 05 that is pretty much stock i have a 4 inch hole in the bottom of my intake and amsoil nanofiber filter and i have a muffler delete i just installed the quad recon gauge set
so my question or problem is that in that form if i punch the throttle in my truck the egts climb to like 1360 or higher in no time (like 100 yard) i have my gauge installed where quad recommends on the top of the manifold in the middle .
so why does this go so fast any ideas could it be the treatment in the fuel for winter making this much difference ???
As long as it is stock with no power adders I wouldnt sweat it.... The
S T E A L E R I mean dealer should fix it....
My 05 and my 07 both would run around 14-1500 when stock...
My 6.7 would do the same too///...
Dont see that you have a tuner or box. Take your pick on one of these and youll see power, milage, drop in temp., and tons more fun to drive. Lots of guys would rec. the smarty, that would be a great chioce or if you dont have 650. to drop you could get like a edge ez or simular for around half that and have pleanty of power. With my tuner the egts are better than stock unless im hard in it on the 215hp setting, and milage is way better than stock even on that setting. TURN IT UP!!!
ok this was before i installed my quadzilla xzillaraider tonight man does it make alot of fun i was mainly concerned that it did it stock now if i put it on 100 hp setting it does it at mid throttle on the 60 hp setting its about the same and i havent messed with the 30 hp setting yet but anyone think it could be the winter fuel treatment making it burn hotter too
this might sound funny but my egts in an hour of hard driving around town and hiting long back roads my EGTS dont even touch 900 and this is on setting 5 on my EDGE. and i do have a heavy foot. (IS IT BROKE!!!!)
Sounds like something else is broke... like your egt guage. You should be way above 900 especially with a stock turbo... Be careful.
I agree. No way an '05 should max out at 900*...stock or with a chip. I would double check that pyro for sure.
