EGT Questions?
EGT Questions?
Can you put two gauges on the same egt probe? Example i need one for the tst, but i want one for my new autometer gauges i just put in. Do i have to drill and tap another hole right next to it? Does it mess with the tst, or egt gauge if you put them both on there? Thanks for your help
I run two, and had to drill and tap 2 different probes. I do not think you can run two guages off one probe. Gave me that chance to see front 3, back 3 for EGTs.
Administrator/Jarhead
I run a gauge and a monitor (snow) off of one probe. I have disconnected them and ran one at a time for a few days, and I did not see anything different.
I do believe that there can be problems when it comes to this, however, I feel that my setup does not give me this. I kind of know what EGT's are normal, so if something takes a nose dive, that's the first thing that I check into.
jmccart
03-18-2007 10:03 PM
jmccart
14
11-20-2006 06:45 PM
