EGT Probe, Pre or Post?
Old 03-17-2006 | 11:06 AM
Mcmopar's Avatar
Normal-mine can drop to 200 on a long downhill.
Old 03-17-2006 | 11:08 AM
RustyJC's Avatar
Coming down a hill, you're only pumping air through the engine. 200 degF readings pre-turbo aren't unusual at all.
Rusty
Old 03-17-2006 | 12:04 PM
PanteraGSTK's Avatar
As far as I have read on this forum. The reason for pre turbo is if your egt's get to like 1500* for too long your turbo goes buybuy. And because of racing and other stuff.
Old 03-17-2006 | 12:22 PM
Mcmopar's Avatar
And pistons, etc, etc.
Old 03-17-2006 | 02:11 PM
Rambunctious1's Avatar
Originally Posted by Mcmopar
I have checked mine, we have a simulator at work so I can do this as needed. Our Simulator has to be calibrated yearly in our line of work. We allow +-5*F. When my gauge says 1500* I know it. We also verify the probes, as I have seen them go bad.
That's pretty cool. I've kind of been wondering if there was any to check calibration on these guages. I've never seen the equipment.
Old 03-18-2006 | 12:02 PM
Grim Reaper's Avatar
Newbie question. What's the best procedure for cooling the engine down when pulling a long grade and temps get dangerous on the pyro gauge?
Just slow down, or pull to the side of the road and allow to idle?
Just curious for future reference.
Old 03-18-2006 | 01:10 PM
torquefan's Avatar
Slowing down a bit, or gearing down to raise the RPM is usually enough.
Also, my thought is that a probe will last longer if it is mounted post-turbo, because it won't see the extreme temperatures. Any opinions?
Old 03-18-2006 | 07:36 PM
RustyJC's Avatar
Type K thermocouples and their thermowells are generally good for over 2000 degF. Why don't you ask how many have had pre-turbo probe failures that have damaged the turbo?
Rusty
Old 03-18-2006 | 11:33 PM
torquefan's Avatar
Rusty
I agree. I have heard that the probes are very unlikely to melt and come apart. I was thinking about the probe simply wearing out and/or losing accuracy.
Old 01-04-2023 | 01:44 PM
bobreeves's Avatar
EGT should be measured pre-turbo. As the hot exhaust gases expand through the turbo's turbine, the pressure drops; so does the temperature, just like any other time gases expand. The higher the turbine inlet pressure, the greater the temperature drop across the turbine.
CORam2
15
03-12-2010 09:40 AM
Captain Coop
02-12-2009 12:28 PM
dodgemaniac
06-05-2007 11:21 PM
imfletcher
04-10-2007 05:00 PM
1bad442
19
01-14-2006 09:12 PM
