EGT probe location twins
Just got my BD 24v manifold for my twin Garrets! Do you redrill on top or mount it in the stock location? Bottom of manifold because it turn upside down?
Mine came with 2 ports tapped by the flange, jtlyk..it's dps's. They're on the bottom by the flange, the back one I have for egt and front one for drive press. (search for drive pressure) and copied willie(??).
DTR 1st Sergeant
What turbo did you put on the bottom?
FWIW, my manifold already came with two pre-drilled/tapped ports as well as described above and I am using both... then I drilled on top for the third... yes, that is right, third, egt probe. I think I need another... can never be too sure!
DTR 1st Sergeant
I don't have pix of that and really am not good at the whole posting pix thing anyway... I'd have to be hand held through it like a little child...
But I have the srt pillar mount for the autometer egt guage, then TST has egt readout as well as the snow stage three water/meth set up. I have two autometer boost gauges and tranny temp in the 3 gauge "over the rearview mirror" pod.
cquestad
03-04-2004 02:26 PM
