EGT probe Help
I was reading on the install instructions on the auto meter gauge that the gauge is calibrated by the length of the wire. You could always try it and see. It should not hurt anything to do that. The worst thing that could happen is that it would read the wrong temp. If the attitude reads a lot different than the gauge then you should drill and tap the manifold again.
Farmboy_92
05-28-2012 10:53 PM
