EGT probe clamp
EGT probe clamp
does the EGT temp probe clamp thing consist of 2 pieces, the part that threads into the exhaust mainfold and the outer clamp piece? or is their a inner part i am missing?
their might be a different style, mine has the probe, then the part that threads into the manifold, then a 3rd part that is suppose to clamp the probe in place, at least thats what i think its suppose to do. their are no threads on the probe itself.
oh, its a ISSPRO guage if that helps.
figured it out, thier is a small compression fitting that clamps the probe when you tighten the outer piece to the inner one that is threaded into the manifold.
also and mine looks exactly like the one pictured.
thanks for all the help, wasnt sure if i was going the get my truck back together. time to get cleaned up and get to bed. thanks again.
Bad Ramer Jamer
12-27-2007 09:32 AM
