EGT Probe Bottoming Out
DON'T GRIND THE STOP RING OFF! I had a freind try that and it broke at the junction where it was ground. If it extends about an inch past the end of the coupler it will be perfect in a manifold mounted application. Like I said earlier, just tap a little at a time and keep trying the coupler until you have about 3 to 4 turns in when finger tight. This will be about 4 to 5 turns in when tightened with a wrench and will put the probe tip VERY close to the center of the exhaust stream. When tightened down you should still be able to see 2 or 3 threads on the coupler.
Richard
Richard
Does anyone know if Dipricol thermocouples are adjustable. I never gave it any thought until I read this thread. I'm not bottoming out, but I'm not exactly in the center either.
John
John
Thanks for the visual reference. On the probe that we are speaking of the compression ring in the above picture is actually a molded in, raised lip that pre-sets the tip depth. Can't be moved or ground off.
Thanks again for the picture. Excellent for reference.
Richard
Richard
Can I hook up two gauges to one probe??
Instead, do what I did (as I was in the same position you're in now) - install the TST-supplied pyro in your downpipe, or elbow, then switch the leads so that the TST box is reading the pre-turbo probe, and your existing EGT gauge is reading post-turbo temps. You now have the best of both worlds - accurate pre-turbo readings for de-fueling, and accurate post-turbo readings for proper cool-down.
Sir Kaos
10-10-2013 10:09 PM
barryp
11-26-2007 05:15 PM
FirstDodge
15
02-04-2007 03:30 PM
