Edge, Van Aaken,Quad?????
Which box should I get please give me the pros and cons of all! And is there any box that sounds better than another, meaning do they changes the tone of the engine, I would think the fuel pressure boxes would, because the amount of fuel delivered is higher, is this true, cause I would like a little extra noise! So help me out guys, which to get:
Van Aaken ( do they even make a box for the 600 motor or just the 555?)?
Quadzilla?
Edge?
Bully Dog?
TST?
Which will provide the most noise, and smoke!
Quadzilla?
Edge?
Bully Dog?
TST?
Don't know about noise and smoke. Most buy for performance... I look at smoke as an added benefit
I ordered the Quad box yesterday after doing quite a bit of research. I've checked archives and current posts on this group and others. I know the quad box is the newest out there, but to be honest, I've not read any negatives on this product. Sure a couple guys had problems with them, but it came down to mfg defect and quad was all over it with their great customer service. Easy install, in cab adjustability, great pricing from Kyle and rave reviews. What else do you need?
I got my Quad box here because it was on sale and also it helps keep this site going. This box is great!! I ran an EZ for two years with no problems but it was just time for more power.. The EZ did not change the sound of the engine but on the 140hp setting the Quad does but it actually smooths it out some. If I hammer it I get a decent amount of smoke now too! The best thing is the in-cab adjustability. I can turn it off if I want or if some punk pulls up beside me at a light I can turn the **** all the way to the right and........ I've been driving this week on just the 60hp setting and will be filling up this morning to check the mileage. Judging by the tripometer the mileage has not changed much, if any, from what I got with the EZ which was 2 mpg less than stock.....We'll see though...
I thought that performance boxes gave you an increase in mileage? Like 2-3 MPG's better, so the quad decreases economy? I want whatever box John Rodriguez has cause he gets tons of smoke!
Dodgezilla I thank was saying the EZ was giving him 2mpg less not Quadzilla. I have installed the New 140 Quad Box on my 04.5 2500. And the low end power is much moor aggressive now. I like it better than the old box.
john rodriguez has a Bully Dog Downloader and it produces enough smoke to cause a blackout in an intersection. I plan to sell my Edge EZ in and get a Bully Dog Downloader because i want smoke.
Most guys put one of these on and Then they play with it because it makes them and for that reason they don't get the advertised mileage gain.
Once you calm down and drive normally without that heavy foot you will see some mileage gains but only if you quit playing with it
Re: Edge, Van Aaken,Quad?????
Quadzilla?
Edge?
Bully Dog?
TST?
Quadzilla?
Edge?
Bully Dog?
TST?
After borrowing king d's VA box I am sold. I like the VA over the Ez, because the over all experience when driving and at the drag strip was better than I had with the Ez. Plus the VA 3.1 is cheaper then the ez. I did have the va 3.1 stacked with the TST and it is amazing. When driving and the va 3.1 set to the lower level and the TST set to 3/3 and 4/4 I could use my cruise control. The drive was smooth like when the truck was stock. There was no increase and decrease in the truck with the cruise set at a certian speed. With the Ez I would set the cruise control and the truck would surge. I also feel with the 3D mapping of the fuel pressure making the power a little bit sooner helped me acheive some great launches at the strip. With my mods I was able to obtain a 14.4 et with a speed of 93.3. My 60 ft time was 1.982. My best before my mods minus the Ez was a 16.637 with my speed at 83.77. As of right nnow I prefer the VA 3.1 over the Ez for increase in fuel pressures. I can not speak for other boxes because I am only using the TST stacked.
The Quad box puts out a little plume of smoke when you stand on it but it clears up right away as for the noise level I have not really noticed much of difference from stock. I have tried all the boxe's and I sell most of them for the amount of power you get and the egt temps you can reach the xzillaraider seems to be the best overall.
Originally posted by Goodys1ton
After borrowing king d's VA box I am sold. I like the VA over the Ez, becasue the over all experience when driving and at the drag strip was better than I had with the Ez. ... As of right nnow I prefer the VA 3.1 over the Ez for increase in fule pressures. I can not speak for other boxes becaseu I am only using the TST stacked.
50%: about a 20HP peak HP gain with a small torque rise at about 2400
100%: about 40 HP peak HP gain with a very flat horsepower curve -- acheived with a high torque rise at 2400 yielding about 75 horsepower best gain over stock at 2400.
just don't try to stack the VA and the Quad together. they are both fundamentally pressure boxes and will try to manipulate the same thing.
no the attitude controller only works with the juice. I had one in my ford but blew the motor with it.... Now I have a real truck!!! I am also looking at the power pup. I don't plan on racing just heavy towing!!!
