Is edge juicew/att the way to go?
Old 11-16-2007 | 06:06 PM
MegaMagoo3500's Avatar
Question Is edge juicew/att the way to go?
So here is my situation. Iam trying to decide wether or not to get rid of my Diablo predator(sitting on shelf in garage) and Dr.performance plug in module and get into the edge products. I love the dr.performace but the predator i had on my truck and did not like it. Truck ran kinda rough and clutches slipped like mad even on tow setting,no adjustability, and the list goes on and on..
The Edge juice with attitude seems to have a little better safety params for the engine and transmission. Plus i love the fact i dont have to add gauges.
I work in the Oilfield so i use my truck truck for alot of bush running and do some towing(11,000lbs) through some pretty serious off road conditions, So im wonderig if you guys can give me an idea as to if iam going in the right direction. This is still new to me so any help would be greatly appreaciated.
Old 11-16-2007 | 06:14 PM
morkable's Avatar
The edge is nice, and for what you are describing it will work fine. The built in guages are definately a bonus. Definately leave in the dr performance as they play well together
Kevin
Old 11-16-2007 | 06:17 PM
omaharam's Avatar
I like mine.
You do realize that just the Dr.P is going to cause you clutch issues, right? If you plan on stacking the Juice and the Dr.P you are going to need a clutch.
Old 11-16-2007 | 06:55 PM
Actually with just the Dr.p right now I dont have any slippage unless towing up hill and i get on it!! But even then it is very minimal. I do realize that any power additive can cause clutch issues and may others. I do plan on a clutch upgrade probably in the spring or sooner but till then i would like a system that i can have fun with but not tear the poop out of my truck. That will come later when i get the rest of the truck up too par with the power. Thanks.
justin mcfall
22
01-30-2008 11:48 AM
roadkill79
04-29-2007 07:48 PM
ocsurf16
10-04-2006 11:19 PM
BlackSunShyne
02-10-2006 05:36 PM
