Edge Juice w/ Attitude ?'s
Old 04-07-2008, 08:42 PM
nottanuff03's Avatar
On an 03 what would be the best stck for a edge juice w/ attitude? Smarty? mp3? what kind of results such as rpm, boost (obviously depending on turbo), HP, you end up with? Thanks!
Old 04-07-2008, 10:54 PM
heykw's Avatar
Good question?
Old 04-07-2008, 11:16 PM
underwoodbits's Avatar
I was looking into the same thing, some say the TS MP-8 works well. But I dont know if that goes for the 03 too. I will probably go with the Xzillaraider II and download the stacking software, they have a couple different ones you can do over the computer with a usb cable.
Old 04-08-2008, 08:20 AM
BlackSunShyne's Avatar
Not sure of the real answer here. But I don't think on an 03 you want to stack the Edge J/A with the MP-8. In the 03 model the Edge is adding pressure, as is the MP-8. That could make bad things happen man, bad things...
Old 04-08-2008, 11:18 AM
haha yeah see im lost on the whole which years does what. Anyone else got some good input? Thanks a lot!
Old 04-08-2008, 02:23 PM
ryan 2500ctd's Avatar
why dont u try a edge juice and and edge ez stack i here that works really well
Old 04-08-2008, 02:32 PM
staarma's Avatar
But once again that's pressure on pressure. I would only recommend the Juice/EZ stack on the 04.5 and newer.
Old 04-08-2008, 02:36 PM
omaharam's Avatar
Diablosport Predator downloader works well with Juice on the 03-04 trucks.
Old 04-08-2008, 08:37 PM
So the predator will only do fuel then? anyone try this combo and have some #'s they'd be willing to share? thanks for the input guys
Old 04-08-2008, 10:54 PM
CG98x's Avatar
I'm running the predator Hotjuice stack and it works well on my truck. You definately don't want to stack more pressure with the juice with it I can see 27000 psi.
Old 04-08-2008, 11:35 PM
Do you run both the programmer and the Hot Juice all the way up?
Old 04-09-2008, 09:08 AM
Dan Marino's Avatar
I run both on Extreme. Level three Predator, Hot #5 on Juice. Never saw more than 24,000 at WOT on my rail pressure guage. Of course I usually just use these two while pulling or racing.
I have the updated tune for the predator saved but have nevr loaded it.
Old 04-09-2008, 11:27 PM
Anyone else run any other combo? Thanks for all the input so far guys.
Old 04-10-2008, 09:28 AM
staarma's Avatar
I'm not sure what "level 3" means on the Diablosport Predator but maybe there's a different one out there. Anyway, some of the puff tunes and RKL tunes are without timing and will stack with another timing box like the Juice while not increasing pressure. I have run that stack by looking at my sig and while it made good power it made very hot power. I need to get a Smarty to try next and then if that doesn't do what I want I'll just give up. The best advice would be to go to the Diablosport web site and register and then read some of the threads. Johan and Mike are moderators there and they can lead you in the direction of the tunes you would need.
Old 04-10-2008, 09:46 AM
DTR Advertiser
kantdrive55's Avatar
We have our Xpower module that is duration only that will stack with any programmer and work very well. It has boost fooling built into it so you will only need a programmer and away you go.
Quick Reply: Edge Juice w/ Attitude ?'s
