edge juice w/ attitude
I really do love mine! Great power and little smoke. Works really nice with a Quad pressure box or the Diablo Predator too! I have found the best mileage to be a close tie with the 3/5 and the 5/5 settings, so mine stays on 5/5, 3/5, 1/5 or off depending on what my Predator has downloaded
Get it! best bang for your buck... clears codes...gage's..turbo timer.. reliable.. good power... mine will turn it self down when you really want it, like when your wanting to really punish your local ford owner, when you meet them buy chance (set your alerts high. I am to chicken my are 40boost 1350egt my buddy says Cummins can take 50psi and 1800F just not constantly)you can turn off all the safety features temporarily... mine did lose all of my inputs all of a sudden one time about eight months ago like it reset but worked fine..had it on for about 15k milesbest mpg is on 3 for me
Well, not technically, its not a downloader and it doesnt reprogram anything in the factory ecm. Once you pull it off the truck, you cant tell it was there.(Unless maybe you pop a code for sumcheck error or whatever, or maybe an overboost code)
No it will not, programmer leave footprint. The Juice is a physical box that you plug into your truck that manipulates the parameters of the motor to induce more power. You plug it in and leave it there physically. If you unplug it then there is no trace left in the ECM i believe.
so is the edge juice worth it? I dont horse around that much i just want fuel mileage increase pulling and not pulling. i pull a 8-10000lbs trailer in summer time and i have a stock 2004.5 ram 2500 4X4.
If you get a good deal here on the classifieds, it is definitely worth it-bought mine for 400 and the ez for 150, so total 550 outlay and the juice came with the a-pillar mount. I actually seen more of a mileage increase from the ez than from the juice (hand calculated,) and I usually keep them both on lvl 1 until someone gets uppity-when that happens all bets are off, mileage does take a hit.
I don't think you're going to see any significant increase in mileage with any power adders except possibly the new Smarty software that changes the timing in a way that no other electronics does. There have been reports of significant gains with a couple of the programs, but I have not experienced it first hand. Anybody else's claim to mileage increase is just hype - in my humble opinion.
