Edge Juice w/ Att question re: turbo timer
Does anyone know if you can set the timer for a few minutes, lock the truck, run into a store, unlock the doors, insert and turn the key to "ON" and drive off normally?
Also, does anyone know what would happen if someone tried to drive the truck while the timer is on without the key in?
I am really leaning on getting an Edge Juice w/ Att, and was wondering if I could safely idle my truck for a couple of minutes without it getting ripped off.
-Chris
-Chris
I have the Edge on my 06' and yes you can do that. You have the option of selecting exhaust gas temp or minutes for the turbo timer. As for theft prevention, the truck shuts off as soon as you touch the brake.
Mike
Mike
"Also, does anyone know what would happen if someone tried to drive the truck while the timer is on without the key in?"
No key in on possition, can't move steering wheel, also won't be able to move shift lever out of park (if auto). Like said above as soon as you touch the brake it will shut off.
As a follow-up question to this, what is the max time you could set the turbo timer to?
I am thinking that if it like 20-30 minutes, I could run out to the truck, start it up and let it idle safely in turbo cooldown mode, until I am ready to leave. Using it as kind of a remote-start w/o the "remote" part of the equation.
Thanks,
Chris
Thanks,
Chris
Thanks,
Chris
Thanks,
Chris
ocsurf16
10-04-2006 10:19 PM
evan4434
10-20-2005 10:41 PM
