Edge Juice - 100% Backdown?
After a rather spirited session the other night I saw this on "someones" Attitude monitor.
I'm not really sure what to make of it. I did a search and didn't find much.
Aloha
Aloha
That means that at some point he had the attitude set to de-fuel based on some sort of parameter and it de-fueled back to stock or it de-fueled as much as possible.
I would not read much into it.
Tell someone he can adjust the Boost and/or EGT limit's upward to reduce defueling. If his truck is rigged like your's he's probably not building enough boost to defuel based on that parameter so it's most likely EGT's that are the culprit. If his EGT probe is pre-turbo 1,350 is a safe cap. At the track I ususally turn this up to 1,450.
Yeah, I've seen that on "someones" display as well. If you are ever racing and want to disable the back down features, press the enter button twice and it will disable the back down for up to 30mins. This will set the truck free and allow you to run a 9.2 in the 1/8 mile, up against a strong headwind
53 willys
38
11-06-2008 11:18 AM
cincydiesel
11-09-2007 01:33 PM
Fast Tommy V
08-12-2007 12:34 PM
razor6
22
01-20-2006 03:43 PM
djcheez
10-15-2005 04:13 PM
