Edge Jammer Injector Tips
Old 03-10-2009, 06:15 PM
  #76
KLockliear's Avatar
M03, 3rd gen injectors are not mechanically fired, so therefore do not get pop-tested.
KKid, DD designed nozzles for the 04.5+ but never had much success with them. We tried an 8-hole, 7-hole and even 5-hole, but between manufacturing issues and QC issues, could not get a good set for production by the time they were shut down.
Old 03-10-2009, 06:36 PM
  #77
Apocalypse's Avatar
Originally Posted by KLockliear
My confidentiality agreement precludes me from getting into the spec of the surface finish, but let me just say it's at least as smooth as a Bosch pintle/bore. This is part of the design/spec for the nozzle as DD/Edge built them.
Good enough for me. Thank you again for the info.
Just got mine in the mail today. As soon as I get a chance, I'm going to go ahead and install these. I've got way to many projects to get finished first though...
Old 03-10-2009, 06:51 PM
  #78
Farmall Power's Avatar
After a person put in the injector tips sould the injectors be tested by someone or is it safe to just run them?
Old 03-10-2009, 09:51 PM
  #79
modified03's Avatar
Just ordered me a set of stage 3 hopefully they will do alright with my stock turbo? how hard are these to put in does anybody have a write up?
Old 03-11-2009, 05:04 PM
  #80
KelschKid's Avatar
Dang (and double dang again to type ten characters)
Old 03-11-2009, 09:14 PM
  #81
DODGER BOMBER's Avatar
Ordered 2 sets yesterday. What specialty or extra parts does one need to install these tips? Also does anyone know what it costs to get injectors checked out?? I want to make sure mine are ok before installing and also wondering what the turn around time on getting them checked is. Any info would help. Also if anyone is installing there's soon, do a write up for the rest of us.
Old 03-12-2009, 01:55 AM
  #82
Stainless's Avatar
I can't wait to see what these will do for my truck... To bad they will lift my head right off my block until I get some studs in....
Old 03-12-2009, 06:17 AM
  #83
pullin hard's Avatar
i don't think injectors will lift your head!!!
maybe if you had a wicked sets of twins with about 60-80psi, then maybe.
Old 03-12-2009, 08:12 AM
  #84
Stainless's Avatar
The twins are sitting here waiting to go in, and I know an s475 pushes more than 60psi with injectors(only around 50psi with stockers). So yeah it will lift my head right off the block Otherwise they would be in already!
Old 03-18-2009, 04:31 PM
  #85
modified03's Avatar
Did you guys get new copper washers or use your old ones and can you do it without the tool to pull them apart?
Old 03-18-2009, 08:01 PM
  #86
DENVERDODGE04's Avatar
22 mm wrench ground down works good for the ''TOOL"
Old 03-22-2009, 02:14 PM
  #87
Thanks man. Just wasnt sure. Does anyone know if these come with the washers?
Old 03-22-2009, 08:02 PM
  #88
Stainless's Avatar
My set didn't come with them.
Old 03-23-2009, 05:09 PM
  #89
modified03's Avatar
were u guys getting your washers from
Old 03-23-2009, 09:49 PM
  #90
Stainless's Avatar
I'm wondering the same thing.... I might have to call up DDP and see if I can order just the washers. I'm not planning on putting them in for quite a while so I've been in no rush.
Quick Reply: Edge Jammer Injector Tips
