With an Edge EZ, will I ever need guages towing
Hey Gary C, welcome back! I have gotten into a dangerously high EGT situation a couple of times pulling in the mountains. If I hadn't had a pyro guage, I could've melted a piston. IMHO, an EGT guage, at the very least, is cheap insurance. I should mention that I do have mild injectors, and that could have added to the high EGT. Still, cheap insurance.
DeWain
DeWain
Re: With an Edge EZ, will I ever need guages towing
Originally posted by Gary C
[/B]
[/B]
Gauges are the first thing I added to my truck and I do not have any power upgrades yet. I think they are a must if you tow or add power.
Kuz......
Truth is it does not matter what brand. All analog gauges need the same inputs and all digital gauges need the same. After you choose which you want analog or digital you are looking at basically the same install no matter what. The digital gauges will use sending units which you will have to install and wire up and the analog gauges will need hard connections to each item to be watched.
Jason
Jason
jrs_dodge_diesel
05-03-2013 09:13 PM
HOHN
20
08-08-2007 08:39 AM
Mike67RS
24
05-25-2004 04:35 PM
PADZZ
08-06-2003 04:33 PM
