Edge EZ vrs TST CR
Old 07-11-2004, 10:11 AM
Push Rod's Avatar
Location: Drive till ya hit a Polar Bear, then go back 50 miles
Re: Edge EZ vrs TST CR
Originally posted by sawboywv1
OK I know they are 2 different animals... but do I need a TST?
Would like alittle more omph. Tow 5000lbs or less in the mountains.
I'd lean to the EZ, UNLESS you are after the best possible low-RPM power. The TST on PL2 will be equal to or higher than the EZ's peak output, however once you get the torque enhancement past TE#1, the TST's bottom side (below 1800) is much stouter.
Rod
bigman
07-21-2005 01:59 PM
mjpalmer
05-19-2005 11:34 AM
Mopar_Mudder
16
06-28-2003 12:50 PM
Mopar_Mudder
30
02-17-2003 04:18 PM
Mopar_Mudder
11-05-2002 10:40 PM
Quick Reply: Edge EZ vrs TST CR
