Edge EZ setting
Edge EZ setting
I have an '03 5.9 with and an edge ez. I have fooled around with the different settings to see if there was a difference in performance and fuel consumption. I have not seen any difference in fuel economy with any of the different levels. Usually 14.5 -16.5; dependent on hwy/city. I have gone a month at a time on one level and so far not a huge difference between level 1 and going to level 4.
One thing I can tell is a difference in performance. There is definately a seat of the pants difference. The manual shows levels 1-4. I have seen posts that have said that there is a level 5 and 6. It even showed pin configurations. Can anyone confirm this?
If so, what is your opinions on performance and reliability of these so-called higher settings??
Any other opinions/experiences with the edge ez box??
The older EZ for the '03-04 does have a secret level 5. I wouldn't run it in that setting since it could pop the pressure relief valve and or damage the injectors.
Some say up to level 3 is safe, and level 4 can damage the injectors over time. I never ran mine past level 3.
MikeyB
MikeyB
If you have an early EZ, before Edge clipped the pins....
1 XX: :::
2 X:: ::X
3 X:: :X:
4 ::: :XX
5 ::: X:: SECRET 5 X:: X::
6 ::: XX:
5 & 6 have cracked injectors, and will not help mileage.
1 XX: :::
2 X:: ::X
3 X:: :X:
4 ::: :XX
6 ::: XX:
:X: :X:
Anyone have any other input.
Thanks for all the responses guys.
I bought this truck 3 years ago and the PO said that this was the only option back in '03 for a 'programmer'. I wonder if this is one of those boxes that have a "secret" level? How could I tell??
Follow the instructions in the previous link you posted. If yours does not have the option you will not see the big gains. If it does you will see plenty of smoke. Remember though, that much pressure IS BAD!!!!!
