edge ez + qd boost fooler = poor idea???
Old 10-28-2008 | 07:13 PM
cns432's Avatar
i have a question reguarding a "stack" if you will, of the edge ez and the quadzilla boost fooler... actually my buddy came across a great deal on an ez and the boost fooler so he decided to buy both...will he see any results from this combo? i told him to save for the smarty and screw all the little stuff but he couldnt wait...can you guys please help me out so i can help him? thanks
Old 10-28-2008 | 08:02 PM
cns432's Avatar
any body?? could yall point me to a thread if this question has been asked? thanks
Old 10-28-2008 | 08:05 PM
bluechrome's Avatar
The Quad BF is not going to do much because the EZ already boost fools. It can't hurt anything tho
Old 10-28-2008 | 09:26 PM
cns432's Avatar
ok cool... well i appreciate the info. i read on edge but i didnt notice that haha. how would you or i guess what order would you put the boost fooler inline with the ez?
Old 10-28-2008 | 09:29 PM
Pitz's Avatar
EZ does NOT boost fool on the 06. I've played extensively with it. Putting the boost fooler in line before the EZ worked the best for me. EZ + the Smarty will work good, but if you have the Smarty, you don't need a boost fooler.
Just set the wastegate to off on the Smarty, and your engine won't defuel when the overboost code is thrown.
Old 10-28-2008 | 10:26 PM
cns432's Avatar
i am asking for my friend. he does not have the smarty, i do but...being that both plug into the map sensor i think, which one should you plug in first the ez or the boost fooler?
Old 10-28-2008 | 10:27 PM
cns432's Avatar
did you like the setup? his truck is pretty much stock...
Old 10-28-2008 | 10:29 PM
georgboy's Avatar
I thought I would let you know I ran the edge ez and quad boost fooler stack loved it.................until I found out that running the edge ez all the time cracked one of the injector cases,That is what me and Tim Barber figured out. Don just got through with my injectors and he said one of the injector cases was cracked and spraying like a water hose. I ran it for about 20ooo miles before it happened all of a sudden.Just be careful about running the ez all the time.If it was mine to do all over I would just get a SMARTY. Hope I helped you a little,Jeremy.
Old 10-28-2008 | 10:32 PM
georgboy's Avatar
Plug the boost fooler into the engine first and then ez.
Old 10-28-2008 | 10:42 PM
cns432's Avatar
i appreciate it.. i will let him know...i told him to get a smarty but he got the ez and fooler for like 220 bux from our buddy soo haha i appreciate all the info.
Old 10-29-2008 | 06:12 PM
cns432's Avatar
anybody have any other suggestions or feed back? thanks for all info
Old 10-29-2008 | 06:16 PM
AH64ID's Avatar
I would have thought the EZ should get true data, then fool to the ECU??
Old 10-29-2008 | 07:22 PM
cns432's Avatar
so ah64id...your thinking plug the ez in first then the boost fooler?
Old 10-29-2008 | 07:32 PM
DENVERDODGE04's Avatar
+1 sounds right to me
Old 10-29-2008 | 08:16 PM
AH64ID's Avatar
yes, it seems the most logical
