Edge EZ on my 03 SO 48re auto? Some questions?
High pressure is regulated via voltage, a measurement of which can tell you the rail pressure without a tap. The EZ changes the pressure by manipulating that voltage. The Edge fellow was talking about a low pressure tap. He said they wanted to get the Juice going as a first priority but they were considering the fuel pressure addition to the Additude down the road as they had had a lot of interest. I sure think they could sell a lot of em if the made it.
just to be precise -- rail voltage is regulated directly by a different signal (ECM to the CP3) than the one used to measure it (0-5f on the fuel pressure port). But you're refering I'm sure here to boxes who themselves regulate pressure indirectly by inserting a voltage error into the fuel pressure signal path. Thats pressure fooling the ECM -- and the ECM turns around and adjusts pressure directly by controlling the CP3.
low-side pressure would be great in a fueling box.
ienjoydrifting
14
02-16-2009 06:28 PM
CTD2001
10-11-2007 08:38 PM
97CTD
07-29-2007 08:22 AM
paward
01-31-2003 04:04 PM
