Edge ez & Bully Dog stack with tst
2006 dodge 3500 drw. i got Edge ez#2 Bully Dog at performace stack with tst 5 hp 2 tq . with afe stage 2 and 5'' exhuast. i took it for a ride and it felt crazy.
do u guys think im runnig out fuel and what feul pump to go with. do u guys think the way i got the stacks at those leves r right
Diesel, I think your running out of fuel, places to connect boxes, and time on that stock tranny and engine. Are you 6speed or auto? Gauges? If you fill out your signature in the cp section more sensible people will respond. ks
I ran out of LP fuel pressure with just HOT Juice/Attitude and EZ on level 2. I went with a FASS, just one of the options I guess. I am happy with the FASS system. Fuel pressure is 18psi at idle, 16-17psi cruising. With BD Triple Dog Performance program, TST w/twins on 7/6 and EZ on Level 3 never got below 13psi at the track. I have decided not to use the BD Triple Dog anymore, just my personal perference. I am running just the TST and EZ for now.
one thing to watch is your rail pressure. the ez does pressure and im pretty sure the bddl does also on performance. those 2 combined is alot of pressure. dont wanna pop your saftey valve or worse hurt your injectors
Originally Posted by Ramirezh
Did you feel a performance hit by removing the BDDL?
I have my BDDL on tow, so it's not doing any pressure.
My turbo needs something to spool it, and the BDDL stacked with the Ramifier works well. In fact, by themselves they run great.
Throw in the TST on high settings and it's just nuts!
The biggest problem with removing the downloader is the complete loss of bottom end. The TST won't start fueling until 10 psi, but then HANG ON! Spool, rev, Shift, PSHHHT, rev, shift, PSHHHT, rev, shift, PSHHHT, rev and you're near 100mph.
I will be sending my TST out to be upgraded to the early twins program after the dyno on Saturday.
Hopefully I'll rely less on the Ramifier (to save my injectors) unless I have to smoke out a ricer.
Topper
03-03-2008 10:17 AM
calfroper
03-06-2007 11:56 PM
MoparRiggan
0
09-19-2005 08:19 PM
