Edge EZ and Bully Dog d/l combo question
I just got an Edge EZ to stack with my Bully Dog downloader. The BDDL is set on tow (the lowest setting). Should I use the boost elbow that came with the EZ in this combo? Thanks.
I use the elbow on my EZ/BDDL stack. I was having some pretty serious EGT issues while towing moderate to heavy loads with the BDDL set to "TOW" (never attempted to pull in the other modes...). After some research, I was able to make a very loose connection between elevated boost pressures and cooler EGT's, so I figured I'd try an EZ on the lowest setting just to get the boost fooling. Works like a champ in my situation!!
JTProuhet
0
02-04-2009 10:46 AM
gpshemi
20
08-29-2007 11:45 PM
TXOVAL
08-08-2007 09:24 PM
