edge boost numbers bogus????
i run the hot juice and have always seen around 36-37psi of boost on my monitor at any hard pull, well i installed a autometer boost guage and found a very different number, i drilled it into the air horn like its supposed to be and now i see numbers like 46-47psi on hard runs, whats up with these numbers???
I have noted this on other posts. Except for the EGT readings(if you install the pyro sensor) all Attitude display readings are from the ECM. I am pretty sure the boost number is after fooling and AK RAM is right that the MAP is electronically limited in how much boost it can accurately read. I therefore do not trust any of the backdown or protection features. I keep my eye on my Autometer gauges pretty close.
sCreamin400
11-02-2008 01:46 PM
CamperAndy
13
02-04-2008 10:13 AM
Capp35
03-26-2006 12:43 PM
coastal_diesel
06-11-2004 09:35 AM
