E Rated 35's or 315's???
Originally Posted by Big Horn
Does any one know of any E load rated 315's or 35's? The only ones I can find are D rated. The OEM 265's are E rated, 3150lbs @ 80 psi. I think the BFG 315's are are D rated 3150lbs @ 50psi. I wanted to go with a bigger tire, but I pull a 24' goose neck, and it is loaded heavy pretty often. Right now I am looking at the Toyo Open Country AT 285/70/17, I think it is E rated at 3750 @ 80psi and I know it is a very good tire, but if there is a bigger size that will carry a good load I might go with it.
check www.toyo.com
Jamie
How many miles are people getting out of the toyo MT's I love this tire but I am on the pavement alot. Got my 05 in Aug. last year, 37,000 miles already, had 8 miles when I drove it off the lot.
Originally Posted by Jmac
Toyo Open Country Mud Terrain has a 35x12.5x17 that is E/10 rated fits on a 8.5-10" wide rim. Overall diam is 34.8 rated to 3640lbs
check www.toyo.com
Jamie
check www.toyo.com
Jamie
Originally Posted by kry226
I don't think many folks actually deny that the Toyo MT is probably the best option for E rated 35" tires for our trucks. However, I think the beef with these tires is the extreme cost and the fact that they are not readily available in the supply system. Almost like the KORE Welds, what happens if you need another in a bad way? You could be SOL.
Jamie
I know they are supposed to have rang E tires , but I also know 15 -20 people that hav put on 315 BFG and none have an issue. I still really wonder if The E tire is not masking a problem that is still there. I run 50 psi in the front and have yet to have issue with a 45K mile truck. That being said, I would PREFER an E rated tire, just in case some day I need that little mask!
That is the truth. I had one heck of a hard time getting a full size spare for my truck.
I've got about 3500 or so miles on my tires. Not one bad thing I would say about them.
Hey guys. I jost got the Toyo M/T 35/12.5/18. with 9.5" rims. I have had the Cooper ST and Cooper STT in 33 and 35/12.5/17's also. I am probably one of the most **** retentive perectionists you could ever know. Without question the toyo's are superior in handling in every way. Took a 100 or so mile road trip and was truly amazed how quiet, stable and smooth riding they are. Just my 2 cents. I also got hooked up by a good Les Schwab. They would tell anyone else they were out of stock. I have spent big $$ as you can see form the previous tires. The Toyo's are hard to find and expensive but worth it. Hope this helps someone make a decision. Later.
Rick
Rick
So what is the point of having a D rated tire that has a load capacity of 3,400 like my nitto terra grapplers if you can't use it because it's not a E rated tire, am I the only one who is confused, why even make a tire with that high of a load rating and give it a D rating, what's the point, who can use it, if it's not safe?
The D rated tire is capable of handling the load but does not have the overall strength of the E rated. The sidewall strength is where the E really outhandles the D. Have a good night.
i think that bfg just came out with a new tire. my tire guy just told me that they have a bfg mud terrain, in a 10 ply e rated. they said they were more expensive but its all what you want i guess.
I'm running 35" Nitto Mud Grapplers that are E rated. I went from 35" Pro Comp All Terrains that were D rated. The difference was night and day. My truck handles like it did with the stock 265s. The Pro Comps walked more in curves and rode a lot more rough.
Hada440
27
09-19-2010 01:43 PM
buddy26
47
01-04-2007 08:25 PM
