E rated 35" tires
E rated 35" tires
Looking for E rated 35's on an 18" wheel. I like the Toyo AT's, but their 35" is only 11.3" wide....seems too narrow. I want an AT, not MT. Any suggestions?
Skinny goes better in the snow and provides better mileage. You can check out my gallery to see what those tires look like.
I ran D rated tires for 40k. The larger D rated tires often have as high or higher load rating than the E rated that came on the truck from the factory. I'll tell you this. The big E rated tires like the Toyos I have now are like bricks. The ride very harsh.
Look for LT325/65R18 with is 35 tall 12.8 wide. There are 4-5 manufacturers that make 10ply tires, Mickey Thompson,Hankook,Cooper. Also quite a few that build 8 ply. Most will be all terrain. Keep in mind that those in an 8 ply will carry more than your stock size 10 ply.
The Vortracks are E rated at 35" on a 17" diameter.
If your not lifted you have to be careful with offset and width when you chage wheels to use an 18" diameter. With stock height suspension it's a tough fit.
I have the Vortrac's on 17" with a level kit and they fit great with stock alloys. I can't find an aftermarket wheel that would fit based on offset with these tires without lifting the truck which would mess up my fifth wheel hookup.
DT <*)))><
DT <*)))><
check the tire specs before you order. different makers measure the tires different ways. Interco and pro comp measure section width of the tire for a given rim where as bfg and toyo measure tread width for a particular rim. Thats why say super swampers are 10" wide on a 35x12.50 and a bfg all terain is 12.3" tread width.
42k+ on my Nittos. I could squeeze a couple grand more out of 'em. They've been a great tire for me. No weird wearing characteristics either. I've been looking hard at the 305's being that they're E rated and they'll fill up my wheel well a little better. They're just pricy though. Especially since I could get a set of procomps for about 1 bill cheaper right now with 3 and 1 deal going. I'm pretty torn as to which tire to get. It seems you hear just as many bad things about procomp as you do about Nitto. The difference being I had great experience with Nitto and none with procomp.
