Dynoed My Truck
Dynoed My Truck
This Weekend I Ran My Truck On A Dyno In Pa. When I Ran It Without The Chips On (just Intake And Exhaust)i Only Had 226hp 445tq Is That Normal Or Is It Wrong
Do you have the 305/555 engine? If so that doesn't sound far off, mine dynoed 247/469 w/ air intake/exhaust, then 362/721 w/ banks on level 6. I dont remember the dyno brand, maybe someone else knows, it's the dyno in Buda at the Viper/Corvette shop??
HP and torque numbers
L8r,..............dogger
what gear were you guys running in on the dyno...and i understand the hp amount just wanted to see if others were the same. tcr when did you get your 6 gun?
My sixgun is SUPPOSEDLY the latest version, that is not PDA compatable version. It is about 18months old. Note, I do have an auto tranny. And I saw a few w/ sixguns/speedloaders dyno and my #s are pretty normal for HP/TQ increases, so I'd say Banks DOES work ok, not quite the junk that all the banks haters think it is.
Goodeyesniper, What settings were you on??
What were the HP/TQ #s for each run? I am waiting for my BDDL triple dog to come in, I am hoping this is a strong stack. I've heard others say it is a great stack, much more power than each by themself.
350hp and 670 tq with them both on. but just now i went out to the truck to get somthing and thought i would look to see if im reading any errors on the 6 gun...yep MAP sensor and 6gun control errors...so i found my problem
Yeah, check and lube the connections, all of my failures have been due to bad connections. I say LUBE because I cant remember what the conductor stuff is called
Dielectric grease. Good luck!
By the way:
My stock #'s were 264/491 a year ago with just exhaust and high flow replacement air filter element from K&N. Just BDPP was 370/704.
By the way:
