Dyno Sheets Bullydog vs Smarty
Old 02-18-2009, 05:48 AM
TORQUE BEAST's Avatar
Originally Posted by SMOKIN-U
just curious why you didnt run pl with the dr p box. imo there would have been more power to be had by doing so. good numbers!!
I am actually going back to do that. Rail pressure was already at 26900 with PL so I don't know how much more I'll get. I am also going to dyno the 2.4.d because we did not test that one either because I was told it would not put out as much power on my truck but it is strong
Originally Posted by Jetpilot
I did a lot of dyno tuning using the 62-66mm turbos. With the 62mm running 42# realized the best HP/TQ. Too many guys crank up the boost but forget the effects of drive pressure......
was your testing done with the 71 wheel?
Old 02-18-2009, 06:02 AM
Thedieselkid's Avatar
If I may ask what are the specs on your 62?
Old 02-18-2009, 01:36 PM
Justice4all's Avatar
Interesting... What were your findings for the turbos you tested.
Old 02-18-2009, 03:34 PM
WYODSL's Avatar
Tell us more. Please
Old 02-19-2009, 08:48 AM
Jason_K's Avatar
here's a little bump. i'd like to know if a 71mm wheel was used too
rams2500
04-16-2010 07:26 PM
gunracer1
02-16-2005 09:11 AM
gristle missile
21
12-27-2004 04:04 PM
DodgeRulzes
09-29-2004 06:19 PM
Monty
10-08-2002 01:12 PM
Quick Reply: Dyno Sheets Bullydog vs Smarty
