Dyno numbers inside
Dyno numbers inside
We were really pressed for time so there was little to no cool down time between runs. We also didn't have a way to read the tach signal so I didn't get torque numbers.
Crazy Larry only: 439 hp
Crazy Larry with MP8 70%: 472 hp
I was hoping for more on that run but I think the intercooler was heat soaked pretty good.
Crazy Larry MP8 100%: 462 hp
Crazy Larry mp8 70% and water with a little meth (~20%): 491 hp
Crazy Larry MP8 70% and nitrous .052 jet: 561.39
Not trying to pump up the smarty but I did the same thing on the dyno a while back with the crazy larry and was upset and slapped on the smarty and gained a bunch.
BDTD CL MP-8 50% Flux 2's and HTT 62-71 stock CP-3 530hp
Smarty Level 7 Tq3 Timing 2 RP 3, all the other stuff listed above w/no mp-8 after 4 or 5 BDTD runs(it was hot) it made 555hp, added some mp 8 and got up into the 570ish range and was losing rail pressure @ 2400rpm so I think I should be up in the 590ish range with a strong cp-3 so what I am saying is try a smarty.
sCreamin400
11-02-2008 01:46 PM
jrussell
37
05-31-2007 08:04 PM
WhiteSport600
59
10-13-2006 06:35 PM
