Dunrite transbuddy
A build valve body from dunrite i believe is around 450. Or you can buy the transbuddy kit for 100 and get someone to set it up for you or you can set up the line pressures and shift points yourself it saves you 350 and has a complete how to guide. And the kit sounds like it is real smooth easy to do kit.
A build converter from dunrite i believe is around 450. Or you can buy the transbuddy kit for 100 and get someone to set it up for you or you can set up the line pressures and shift points yourself it saves you 350 and has a complete how to guide. And the kit sounds like it is real smooth easy to do kit.
TXGREYGHOST
37
02-19-2007 01:18 PM
streetsmoker
11-01-2005 09:49 PM
