Drive pressure gauge
I would get at least a 60. In a lot of cases you driver pressures will be higher than or at least as high as your boost. You want it lower but high boost with small chargers ramps it up. If you are pushin more than 30 lbs of boost it would not be enough. I may just go ahead and get a 100 lb guage for mine, just in case.
My only question is why? If you have custom twins that havent been tested than sure. But if you have a set like BD or ATS they have been tested from the factory. Also you can find threads of other people running drive gauges and their results. But if you just want another gauge or have the money go for it. Its just my understanding you run copper from your exhaust manifold, and your gauge is gonna take some serious heat and not last for long. Just what Ive read, I have never run a drive pressure gauge cause I dont want 1300+ degrees running up to a gauge.
I guess I see your point but I want to know as I modify the truck and with different setups what Im getting first hand. It just takes some of the guesswork out of it. I wonder what would happen if I used the sender for like a digital gauge like the commander and then just used there boost gauge as a DP gauge. What would be wrong with that? Anybody else doing that?
Our TIP gauge kit uses the same hole as your EGT probe.
Because no two 'charger setups necessarily run the same TIP, and because different fueling tunes usually alter the TIP/boost relationship.
You're correct about the copper lines from the exhaust manifold being an unacceptable method of plumbing a TIP gauge - the CTD engine environment is very harsh (lots of vibration and heat); that's why our TIP gauge kits are designed to operate under those conditions indefinitely, while still maintaining a remote readout in the cab.
I wish we'd gotten a 100lb unit for the TIP kit - the 60lb version pegs the needle at 75psi!
Why?
Why?
Would you sell the kit minus the guage if, say, oh I dont know, someone had a spare boost guage?
Shoot me a price if ya dont mind.
Of course - that's how the TIP kit comes standard (w/o gauge), so each person can have the exact style they want in their truck... connection to a 1/8" boost tube is standard, but other sizes are available upon request.
Hope to have all the info up on the site next week!
Tony (trik396) recently received a TIP guage kit - he'd probably have some feedback for ya...
Tacsavage
02-21-2008 08:03 AM
