Donaldson Muffler Install Question
Installing the Donaldson Muffler on the MBRP turbo back straight pipe exhaust. Question is which way does the muffler go ? This may be a dumb question but I have searched all over to see which end of the muffler goes toward the front and which end towards the rear. There is a vortex end and then just a straight through end. Any suggestions?
Donaldson Muffler M090544
These mufflers are meant to be mounted vertically. With that being said, they are made with one end rounded out for rain to bead off. The dented in end is the inlet.
mine also had an arrow - but i ignored it. i looked through the muffler to see which way is best. if looking through one end you will see some cones or baffles that will 'catch' air. if you look through the other end you will see it is more free flowing.
i ignored the arrow and chose to mount it in the more free flowing fashion. if needed, i could just take it out and turn it around to quiet it down a bit but i really don't think it is much louder than when it was stock.
if you follow the arrow it will be quieter and less free-flowing.
if you mount it against the arrow it will be a bit louder but more free-flowing.
scottylucas
12-20-2011 05:45 PM
stock03
04-17-2011 05:42 PM
Adieselbrother
10-06-2009 07:12 PM
CalypsoCowboy
08-20-2008 07:11 PM
dodgedude361
03-12-2004 12:29 PM
