Don Thuren is the Man!
Maybe a 1-1/2" front and back...1/4" groove/fillet with 7010.
It would take all of 10 minutes to remove it with a grider/cuttoff wheel if needed.
After installing my lift, 2 months later I noticed some slop in the back and one of the blocks had turned 1/2" or so, even though the U-bolts were tight.
Did you need any angle shims for the added height? or did the blocks you used have 2*-4* "built in"?
Not sure if 1" blocks have any angle to them, or if ill need an angle shim with the Mini-pack/1" block.
I think he was asking if it would add any angle to your rearend for pinion angle. The ones you made were out of solid 1" stock or did you mill it at an angle?
What about going with the 4 inch Skyjacker Leafpack, you would have the rear a little higher( probably just like stock-same angle) that would get rid of the axle wrap. I am going through the same dilemas with what to do with rear?
Ill be doing the same soon, the superlift front coils are junk, way too stiff, and ill probably get the mini pack setup too to help out the ride.
Havent ran the skyjacker setup, but im guessing its the same way, youll get the height you want, but wont ride as well as it could
silkywoods
17
12-03-2007 05:09 PM
rjm022
06-30-2007 02:54 PM
reidry
15
12-20-2005 09:35 PM
Lsufan78
05-24-2004 12:25 AM
