? For Don M...
Old 01-31-2008 | 07:41 PM
04DEEZELRAM's Avatar
Question ? For Don M...
I was wondering if you could injectors from a marine engine in a 305/555 engine, the injectors came out of a engine with a horespower rating of 380hp, and are the spray pattern different. Thanks....Jon
Old 01-31-2008 | 08:07 PM
Kman9090's Avatar
At taht much fuel your spraying in there it would take an extreme turbo to burn that off. I think you would be changing oil after every run since you would probably wash out your cylinders every time.
Old 01-31-2008 | 09:16 PM
its only 75 more hp then my engine now
Old 02-01-2008 | 01:14 PM
C Schomer's Avatar
I think the bigger issue would be if they will work right with your piston bowls. Craig
Old 02-01-2008 | 10:19 PM
ya thats what im worried about
Old 02-01-2008 | 11:07 PM
CReed's Avatar
Have you compared the two side by side. The common rail cummins marine injectors I have seen have had a longer injector body then our truck, the top solenoid looks to be the same as does the bottom half of the injector body and nozzle just longer. The spray pattern I would imagine might be a tad off as well and we wouldnt want that.
Old 02-01-2008 | 11:11 PM
displacedtexan's Avatar
Not exactly the same, but 12v guys have been running marine injectors with the wrong spray pattern for decades (155* instead of 145*) with no damadge. They are smoky though.
Even though there are many newer, better options many still run them because they are good bang for the buck.
Old 02-01-2008 | 11:17 PM
Ya i forgot the 12v use marine style injectors, i still might try them out since they where free, and i have a coulple extras to mess with.
Old 02-02-2008 | 12:02 AM
CReed's Avatar
Post up some pictures of them.
Old 02-02-2008 | 11:07 AM
revolution_dsl's Avatar
watching this...
Old 02-02-2008 | 11:44 PM
Ill post some pictures for yall tomorrow
Old 02-03-2008 | 08:42 PM
There's a picture of one of the injectors
Old 02-04-2008 | 02:14 AM
Kman9090's Avatar
Oh I thought you meant 380hp over the stock 305. Most injectors are based on the horspower they have over stock. Sorry about that, I wonder if those amrine injectors have the failure rate of the ones in our engines. Another one of my buddies is making oil and white smoke. Number 2 injector is shot. I think he caught it before he wipe out the piston so far. I trashed my motor because of it.
Old 02-04-2008 | 06:43 AM
So far we havent had any injectors fail in a boat, i guess if i cant find out if they will work looks like ill be putting marine pistons in my truck so i can use them
Old 02-04-2008 | 09:56 PM
bump...................
Quick Reply: ? For Don M...
