Does the fass work good with its' draw straw?
Old 07-14-2009 | 12:07 PM
sallyman1's Avatar
my dealer is going to fix my fass problem right this time. they are going to install the fass draw straw that came with the fass kit in the first place. They are doing it right this time. i cant believe they took a shortcut the first time. I think because my fass kit is a fass95/150 is the reason why it didnt work with the factory canister. maybe if i had a 100gph instead the factory fuel canister would of worked. anyways do you guys know if the fass draw straw works or is there any problems with it? should they make a hole and put a grommet in it?
Old 07-14-2009 | 04:01 PM
klx650a2's Avatar
Make sure the tubes are long enough also. The tank sags a bit with a full load of fuel and if its not measured with the sag, you'll run out at 1/4 tank. And that sucks.
Old 07-14-2009 | 04:09 PM
sallyman1's Avatar
i already am running out at 1/4 tank
do u have to extend the tube? or is it cut short from fass?
vj_M
02-05-2009 10:58 PM
greenworks
12-18-2006 10:42 PM
greenworks
12-18-2006 05:31 PM
00' Quad Cab
09-27-2006 02:27 AM
