Does anyone know the cab or body mount torque spec?
I was putting side steps on a friends truck that required the removal of the front and rear cab mount bolts, did not say the torque spec and was wondering if anyone had it? thanks in advance
Cummins Guru
TORQUE
TORQUE SPECIFICATIONS DESCRIPTION N·m Ft. Lbs.
Cab mount bolts 81 60
Cargo box bolts 108 80
Front crossmember bolts - 2WD (light duty only) 61 45
Front crossmember bolts - 2WD (heavy duty only) 75 55
Front crossmember bolts - 4WD (light duty only) 102 75
Front skid plate bolts 34 25
Lower bumper support bracket bolt 54 40
Radiator crossmember bolts - lower 28 21
Radiator crossmember bolts - upper 28 21
Rear crossmember (light duty only) 102 75
Rear crossmember (heavy duty only) 115 85
Rear spring shackle bolts 163 120
Spare tire winch bolts 41 30
Trailer hitch reinforcement bracket bolt 170 125
Transfercase skid plate bolts 34 25
Transercase skid plate crossmember bolts 34 25
Transmission mount to crossmember nuts 54 40
chopper698
01-01-2015 11:24 AM
Racing_Joe66
03-23-2014 01:52 PM
itr.#1446
04-05-2008 06:24 PM
drewallen42
04-14-2007 01:07 PM
