Do I get a stage 1 or stage 2 afe
I am running full stock and would like to get an afe intake. Which on do I get and where do I order the outerwares filter for this intake? Will i see much difference between the 1 and 2?
The thing about the Stage II is that even though the air filter outlet is 6inch, the turbo inlet is still only 4inch.
Its like having a 6inch firehose, but only a 4 inch drain.......you can still only flow 4inches of air![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
The big thing about the stage II is that it gets rid of the silencer tube (the black baffle thing-a-gig)
The stage 2 intake tube is more of a velocity stack as well versus the old toque tube. The stage 2 flows much better but you also get some sound out of it which I love but some may not.
Not arguing that the filter flows more air....with the 6inch outlet it should flow more than the 4inch.
But the 6inch outlet is useless, because the inlet into the turbo is still only 4.
It would like me having a 12inch outlet, but still a 4inch turbo inlet. You can only pack enough air that will fit through the 4inch inlet.
i would get the stage 2 intake. i was able to suck the filter chack button shut with the stock turbo on the tst box all the way up. i would also like to note that you will more then likely be upgrading the truck even further then what you have anticipated. so i would much rather spend the money once then have to find someone to buy your stage one and then buy a stage 2. less hassle in the long run.
Big Red PSD,
Remember you're not flowing water, the turbo is creating a suction, unlike gas vehicles where you are relying on barometric pressure to supply the air volume to the engine. The velocity effect of the 6 to 4 inch tube and the suction of the turbo as well as the larger filter all work to provide a pretty siginificant difference in CFM of air supplied.
Mark @ DPPI
Mark @ DPPI
sinawalli
03-05-2011 08:43 PM
3500eh
07-29-2008 04:53 PM
TORQUE BEAST
06-08-2008 07:53 PM
goodeyesniper75
08-29-2007 11:54 AM
