DIY / Homemade Projects - Reference List
Ok, I've been having the bug on doing a project, so I figured while I was searching, I'd list some here. These are projects I'm finding on DTR that have lists of parts and images (for the most part). I'm trying to keep it to ones you can read, then go DO! So if you have some, list them here so we can spread the love while some peoples pocket books are tight, and need for speed is high!
Famous ****** Whistler Intake
~ $85
Homemade 4" intake
~ $95
Homemade Crankcase Vent Breather Tube
Homemade Intake Horn
Homemade Intake Horn 2
~ $50
Homemade LP Gas Mod
~ $100
Homemade Propane System
~ $175
Homemade Torque Tube
~ $50
~ $85
Homemade 4" intake
~ $95
~ $50
Homemade LP Gas Mod
~ $100
~ $175
~ $50
i've been hoping for awhile we'd have something like this all put together edited with a link to go straight to and choose the mod you want to do
didnt see all of this on wiki
good job
good job
Hey man,
I jus did my own pressure coolant relief valve for my truck for around 68 bucks. I tested it and it dropped my engine temp from 235-240 down to 210 at the end of my sled runs. I studied the opie kit and wicked kit...read a bunch and made mine out of 3/4 heater hose and a ball valve. Of course it isnt as pretty and I have to turn it on and off manually but I saved close to 300 bucks and it works perfectly taking heat and pressure away from #5 and #6. Advance has a neat little T setup that works where you put the water back into uper radiator hose. No pics but very easy to make.
~ $85
Homemade 4" intake
~ $95
~ $50
Homemade LP Gas Mod
~ $100
~ $175
~ $50
~ $85
Homemade 4" intake
~ $95
~ $50
Homemade LP Gas Mod
~ $100
~ $175
~ $50
Dont' forget the air conditioner mod. Less then $20
https://www.dieseltruckresource.com/...highlight=cold
To lighten the front end and to make room for the grand-daddy-of-all air filters, I moved the batteries to the back. I built batt. boxes and bolted them to the outsides of the frame, just behind the cab and made new cables with 2-0 welding cable. Craig
on the *****'s whistler intake does it make the turbo whistle louder or wat kind of sound does it make? cuz all i hear is that its louder and not really sure wat uguys r talkin about.
yes, the whistle is louder. For a real loud whistle, follow ****** instructions exactly. I went down to a 4" cause I didn't want it too loud, and I'm REAALllLLLLL happy
did the ****** whistler intake and wow amazing sound...need to make a heatshield and for some reason my intake does not sit as far forward as your guys's so i might order the 6" 45degree elbow so the new amsoil filter sits in the stock spot
