DIY CP3 mod Piece of Cake
Old 04-22-2007 | 12:43 AM
tbarbee1's Avatar
Talking DIY CP3 mod Piece of Cake
I modded my cp3 this morning and it was even easier than expected it works great a little more smoke... quicker throttle response...and more low end power...smoother power through acceleration the only trouble I had was dropping a bolt and spending 20mins looking for it it is a simple easy cheap way to gain power Ive heard of surging and other problems but it seems to be working with out any complications so far
After all this is the type of thing that keeps us Diesel nuts goin doing something yourself for free that would have cost big $$$
Old 04-22-2007 | 01:53 AM
reidsram's Avatar
i am interested in this mod. did you do it just like its posted on this forum? are you a mechanical genius or could someone with a little less talent do this mod? i am glad it worked out for you
Old 04-22-2007 | 02:29 AM
labreck's Avatar
where is the post for this mod?
Old 04-22-2007 | 09:24 AM
Luvnacumns's Avatar
Here ya go
http://relentlessdiesel.com/forum/viewtopic.php?t=19
Troy, so it's as simple as the write up! I feel pretty confident I can do this!! If time permist next weekend it'l be done.. But I am hoping we will be slapping that little turbo on!!
Shane
Old 04-22-2007 | 09:31 AM
Luvnacumns's Avatar
How much more smoke did ya get??? Not that is matters with the smarty/mp-8 because I can blow a solid line of smoke for atleast 3/4 mile But it is good for tailgaters!!
Old 04-22-2007 | 09:51 AM
tbarbee1's Avatar
Its just enough more to be noticeable but Im only running a SC programmer on performance I think with a real box or stack it would be alot more.
Old 04-22-2007 | 09:59 AM
tbarbee1's Avatar
[QUOTE=reidsram;1472507]i am interested in this mod. did you do it just like its posted on this forum? are you a mechanical genius or could someone with a little less talent do this mod? i am glad it worked out for you [/QU
I am no genuis or a mechanic if you are fairly apt at using hand tools and can undrstand the link shane put up you wont have any trouble. Its not like a can of snakes there arent many parts inside what you will be taking apart. Its kinda unnerving to take parts off a truck that only has 12,000 miles on it especially PUMP parts but it worked out ok for me. THere are several posts on this about surging afterwards but the majority of the surgers re posted and had no problems after taking it back out and cleaing up the valve like they should have the first time. Make sure it doesnt have any burrs on it inside and out.
Old 04-22-2007 | 12:17 PM
05SilverBULLET's Avatar
Yea guys.. i just did mine about 5 minutes ago. took me about 45 minutes for everything and so far so good. i will be going out and testing it in a little bit and will post back the results.
Old 04-22-2007 | 12:32 PM
ok... i just had to go out and try it. theres a lot more smoke, my fuel pressure guage is completely drained with the Diablo on Extreme and the Edge on level 5. its wayyyy time for a pump. but to sum up the install and the performance.... i probably wont see any benefit until i get a lift pump kit and get some more fuel to the motor. but it definently supplies more fuel, that for sure. good write-up and it went together exactly the way the directions say it will.
Old 04-22-2007 | 12:44 PM
OldSmokey's Avatar
Its really easy, just dont over tighten the three t25 bolts when you put it back together, i still cant get mine out, i just twist the t25 head, think ive gone through 5.
Old 04-23-2007 | 03:07 PM
Luvnacumns's Avatar
Cool. Sounds easy!!
Shane
Old 04-23-2007 | 03:15 PM
dodgezilla04's Avatar
you havent done it yet? what did you do all weekend?
Old 04-23-2007 | 03:17 PM
Luvnacumns's Avatar
Fence!! I went to home deepot and got a stupid idea!! But momma likes it!! So score! I should be outside doing it right now but it's been raining and my buddies shop is all tied up so I can't use it.
Shane
Old 04-23-2007 | 03:18 PM
are you retired? not working on monday at noon? hmmmm, must be nice!
Old 04-23-2007 | 03:27 PM
Luvnacumns's Avatar
Nope, just got rained out!
