DIY CP3 mod
Old 03-18-2007, 01:26 PM
  #136
Mark1si's Avatar
Are you having any pulsating in rail psi?
Old 03-18-2007, 04:27 PM
  #137
OldSmokey's Avatar
Well did my pump mod and it does feel like there is more power there. I used 6x2 usually (5x2) on the tst and 50% on the mp8 and if i punch it in third the tires go up in smoke. Its definatly worth the time.
Old 03-18-2007, 04:45 PM
  #138
dodgezilla04's Avatar
Glad it worked out for you.
Old 03-18-2007, 05:09 PM
  #139
Speed Shift's Avatar
I did mine this weekend too.
All I am running at the moment is a EZ, but you can tell it is working. I noticed better power at WOT. I think it would be way more noticable power for someone draining the rail. I think this mod, and a dual feed line would be great for the guys stacking boxes or running injectors. I had some startup issues, but I pulled it down again and polished the little thingy-ma-jiger down and it hasnt had any problems since. Ad removed site violation
SPEEDSHIFT out.....
Old 03-18-2007, 05:21 PM
  #140
rich2500's Avatar
glad too see more guys givin these mods a shot
Old 03-18-2007, 09:01 PM
  #141
Wasnt raining today so took the truck for a ride with my kids(they love to hot rod).
Set the smarty on level 8 wild, quad race on 140, smoke switch on, and of course DIY CP3. Went to the parking lot where I park my bus. Here is a run by with my 9 year old son taping. http://video.thedieselgarage.com/vid...f5016af7e4.htm
Old 03-18-2007, 09:23 PM
  #142
w.tx iceman's Avatar
Help out a dummy, what is a smoke switch. As much as I read on here I guess I missed it.
Old 03-18-2007, 09:41 PM
  #143
Smoke switch is a simple on/off toggle that tricks the ecm into thinking you are a full boost when you are really at low boost levels, gives you full fuel right NOW. The benefits are faster spooling, but also gives a nice puff of black smoke until the turbo spools.
Here's the link to the thread about it.
https://www.dieseltruckresource.com/...t=Smoke+switch
Old 03-18-2007, 09:42 PM
  #144
Couple of quick pics of the CP3 mod and notes on tools.
[IMG][/IMG]
[IMG][/IMG]
Old 03-18-2007, 10:21 PM
  #145
53 willys's Avatar
nice pics and report dodgezilla04
Old 03-18-2007, 10:27 PM
  #146
the only way i learned was from reading posts and looking at pics. i suppose it is my turn to repay the favors. and it is really fun too!!!!!
Old 03-18-2007, 10:43 PM
  #147
drewblood's Avatar
isthere any way the next one who does it could take step by step pics it sounds easy but IM a picture guy but dont want to trash a $$$ part
Old 03-18-2007, 10:55 PM
  #148
go back to the beginning of this thread and print out the pics that chris of relentless provided. very good instructions, and those are what i used to do mine.
Old 03-19-2007, 05:00 AM
  #149
rich2500's Avatar
drew, use the pics from relentless and take your time,two most important things are make sure everything is clean and make sure when you install the valve back in the fca it slides in very easy,the sticking valve seems to be the one that has been getting alot of people,including my self,I'm glad I pulled mine back apart and found the problem,it has probably saved a few people from alot of headaches,not just here but other forums also.
Old 03-31-2007, 08:56 AM
  #150
wap
wap's Avatar
I know this may be a dumb question but these are delicate parts.
Wouldnt a zizwheel work just as well as a dremel?
Also when it mentions the mechine screws in the relentless artical, is the gear cover threaded or do we need to put a nut on there?
Quick Reply: DIY CP3 mod
