Ditching Crazy Larry Now What???
Ok My Last Set Up Was A Juice Stack With The Power Pup And Made Good Power And Never Too Hot. Got Rid Of That And Went To The Triple Dog With Crazy Larry And Waaayyyy Toooo Hot. Ok I Know It Makes Tons Of Power And Almost Too Much For A Stock Turbo But Even On The Extreme Setting Before Larry It Was Still Too Hot. I Have Added A Quad Boost Fooler And I Know Others Have Had Issues With This( Not Quads Fault Its A Bullydog Thing For Sure) So What Now. I Love The Power But I Can Only Use It For 3-4 Seconds And Thats It. Do I Go Back To The Edge And Get The Hot Flash?? I Was Thinking The Smarty But I Like Having The Change On The Fly Option. Im Lost On This One. What A Good Proven Box Thats Goos For A Stock Turbo. I Dont Need Anything Crazy But I Do Love The Crazy Larry Power. Any Ideas Would Be Great. Thanks
jb903 How hot are you running?My BDDL runs hot to. But whats your boost reading around 19-20 thats what mine did.I could hit 1350-EGT seems hot but with the MP-8 turned on low seems to help and the BOOST-FOOLing.
(My 05 ran alot cooler than my 06)
Instead of getting a new box, why not put that money towards a new turbo, then you could stack something with your Crazy Lary. I was under the impression that the CL program was too much for the stock turbo to begin with.
thanks. Mt stock turbo w/CL XZT stack will hit 1300 but have never run it so hard for it to go higher. I have to do some major 5th gear pounding to do that. On the dyno it never got over 1200deg and 480hp!
when my boost fooler is getting along with the triple dog and it makes 42lbs of boost it doesnt get too hot but most of the time the boost is at 25lbs and in seconds it gets too hot just on the extreme setting. im not really looking to stack again just would like usable power. crazy larry is alot of fun but not for a stock turbo with boost limitations. so what should i try next. i really cant do a turbo now cause then i need studs and i might as well do a set of sticks then oh ya full built trans. im going broke...... never mind i am broke.
MOJO1
18
03-23-2016 06:47 PM
smoky05
22
11-30-2007 08:26 PM
huntingdeer
09-17-2007 09:34 PM
HeberRam
03-30-2007 05:37 PM
Snojumper
34
03-18-2007 12:27 PM
