Disappointing Dyno
Old 09-15-2008, 08:52 PM
  #31
OutOfSight's Avatar
Originally Posted by SmokinDodge12V
500hp on a commonrail with a stock turbo is done easier than you seem to think.
He didnt say 500 he said 552. Either way though If their are really 550HP trucks on stock turbos(dodges) show me one runing some good 12's. Dynos lie, the track doesnt.
Old 09-15-2008, 09:10 PM
  #32
SmokinDodge12V's Avatar
Originally Posted by OutOfSight
It's very possible that the time before their was just an error on your trucks run(s). The 515HP just isnt possible with the stock turbo, your numbers seem very normal.
No actaully you said 515hp wasnt possible and Im saying that it is very possible.
Old 09-15-2008, 09:15 PM
  #33
OutOfSight's Avatar
Did you see the either way part of my post by any chance? Like I said show me one of those trucks with a stock turbo runing 550 or 515 horsepower passes at the track.
  #34
My truck doesnt have 500hp but if I could get it to hook up in the 1/4mi I would be close to the high 12s.
Old 09-16-2008, 12:48 PM
  #35
Hintz's Avatar
With 552 horsepower a truck should be able to run like a 12.75 in the 1/4. The best I have seen out of a stock turbo dodge on #2 doesnt come close to that. On a dyno with a huge correction factor or something yeah its easy to "play" with things to make it show that number but in the real world theirs just no way. This is where dyno's are so confusing. I've seen truck hit 720 on one dyno, then almost 100 hp less on another. Alot of shops will want higher numbers so their customers are happy and sadly enough that makes for some funny numbers.
Well its a 6speed so no 12sec runs, but I dont know what to tell you b/c it was at Commerce Ga for the Hayes Diesel Drags, it was Dunbars dyno (and all Dunbar does is go around the counrty w/ his dyno to dnyo people) and there where quite a few people ****** b/c of their low HP #'s.
I guess I got lucky or something and tricked the dyno or something.
Also I know one other guy in a 05 that made 555 hp on his stock turbo. That was Robert w/ NGM Diesel
Old 09-16-2008, 01:36 PM
  #36
OutOfSight's Avatar
Theirs no room for if's in drag racing, if it doesnt it simply doesnt.
Old 09-16-2008, 02:02 PM
  #37
PourinDiesel's Avatar
In a perfect world track times will equate with horsepower. However not all trucks/cars etc. are setup for drag racing so to equate track times with horsepower is only somewhat of an accurate measure and does not tell the whole story.
It is a reference point and tool but that's about it.
My truck is right at or under 700rwhp on a chassis dynojet. I bet I could not click off a 14 in the quarter mile if my life depended on it. Does this mean the dyno is lying to me as well?
Oh yeah, I remember a 12 valve with a stock tranny and HX35 that squeezed off a 12.9 several years back.
On another note:
I remember the days when several of the prominent diesel guru's in the industry swore up and down that 1000 hp out of 5.9 was not possible and could not happen. Also many of the west coast guys agreed with this and now 1000hp is for a street truck.
The same trucks that were 1000hp back then are now 2000hp+/- on an engine dyno.
Old 09-16-2008, 02:33 PM
  #38
staarma's Avatar
A couple things to check on that Superflow. The first and foremost is the calibration of the load sensor (torque cell). The second is the RPM measurement and why he could only show you numbers from 2900 and up. The third is the tire slippage. The fourth is the correction factor used. He actually said he corrected it to Dynojet numbers? Holy smokes that insane. It either reads correctly or not. Model 248 Dynojets use pure inertia so they read consistent, no load sensors. The only way you can make them inconsistent is try to cheat the atmospheric conditions measurement or cut a piece of the steel drums out with a torch, that's it. Put it on a Dynojet and then repost your numbers so we can see what's going on. It seems low to me.
Old 09-16-2008, 03:22 PM
  #39
CoolumConst's Avatar
I talked with the machine shop that has the dyno. They said the calibration is good, he said they read the rpm's so it would not down shift???. As far as the correction factors, Superflow programed it so the numbers would be closer to Dynojet numbers rather then Superflow numbers, so that was a Superflow thing not the operators correction. The other correction was the atmospheric conditions that the computer makes using the weather station. He said all the setting have stayed the same since the dyno in April.
SO if the April numbers were correct, what is the problem with my setup?
Old 09-16-2008, 06:24 PM
  #40
The point is that just becuase a truck dynos a certain number does not mean that its going to run a certain number on the track.
RickG
05-01-2007 08:15 AM
BigBlue
40
02-07-2007 08:29 AM
Smkn600CTD
29
02-05-2006 05:53 PM
Meatball
20
08-08-2005 08:38 PM
Jones0027
38
05-09-2003 12:25 PM
Quick Reply: Disappointing Dyno
