Differences in rear axles?
Old 11-26-2004 | 02:23 PM
davelinde's Avatar
I'm looking to buy a new pumkin and found this site
http://www.dieselperformanceparts.co...bc&f_match=200
Per my glovebox I've got an 11.5" rear axle with a 3.73 gear ratio. The application note for 2003+ says to check using VIN to make sure I've got an 11.5" ring gear...
If the glove box says I've got 11.5" rear... does it mean the ring gear? I hate ordering parts that don't fit.
Old 11-26-2004 | 03:43 PM
blown32's Avatar
Yep it does. Should be the only one for a HO or any 04.5 and above.
Old 11-26-2004 | 06:27 PM
Gypsyman's Avatar
I've got a set of the PML's sitting on the bench. Ordered direct and they are very nice pieces. You won't be dissapointed.
Richard
Old 11-26-2004 | 07:54 PM
Jerry R's Avatar
Gypsyman,
What finish did you get? I can't decide.
Old 11-26-2004 | 08:23 PM
Gypsyman's Avatar
I went with the black powder coat so it wouldn't stick out like a turd in a punch bowl under the truck. If you keep your axle painted it looks very clean from the rear. To each his own...
Richard
Old 11-26-2004 | 08:40 PM
suzukiZrider's Avatar
Richard
a turd in a punch bowl thats a good one
Old 11-26-2004 | 11:13 PM
mudslinger's Avatar
I checked my glove box and all it showed was an anit-spin code. Which character in the VIN tell the tale on the rear end?
Old 11-26-2004 | 11:19 PM
blown32's Avatar
mudslinger, From what I have read the SO with an auto should be a 10.5". Check with your dealer to make sure before ordering parts.
Old 11-27-2004 | 11:31 AM
davelinde's Avatar
OK... so there were differences in how DC equipped SO and HO for a while? That would explain the cryptic application notes. But with my HO pre 04.5 2004 I'm thinking I've got the only flavor of 11.5" rear there is and the new cover should fit me.
Old 11-27-2004 | 01:13 PM
CTDinMT's Avatar
All 1-tons have the 11.5", regardless of tranny or SO/HO. If it's a 3500, its got an 11.5". It's the 3/4 tons that varied on the ring gear.-Steve
Old 11-27-2004 | 03:15 PM
Gypsyman's Avatar
Call the manufacture. PML Incorporated. There have been a couple of p/n updates in the last few weeks. They will make sure you get the correct parts.
Richard
Old 11-27-2004 | 05:11 PM
davelinde's Avatar
...yes, I tried to call the number but I'm thinking they took a long weekend.
I'll call on Monday before I order. I've learned to gather info before I call. If the person know what they are talking about, I can ask better questions if I've done my homework. If they don't know what they are talking about, I can figure that out by knowing a little about the question myself.
This one should be a no brainer.
Old 11-27-2004 | 05:35 PM
Gypsyman's Avatar
A little off topic but worth note. I went back and checked my info. The change in p/n is for the front axle. Our front axle is the unit used for the rear axle on the new Hummers. GM apparently relocated 1 stinking bolt hole for the cover on the Hummer rear causing PML to have to change the alignment for the Hummers by less than 1/2" on that hole. If you go for a front cover also, check the holes for alignment before you proceed with the install to make sure you don't get a Hummer cover from a vendors old stock.
Just a little info for future 4x4 users...
Richard
09-22-2019 07:27 PM
95black2615
12-22-2007 10:54 PM
bigbrowndog
09-02-2007 08:16 PM
SkyHarborCowboy
15
09-09-2005 11:50 PM
Quick Reply: Differences in rear axles?
