Diesel shop in Phoenix open on Saturday?
Does anyone from Arizona Phoenix area know if there is a diesel performance shop that is open on Saturday. I am up for the weekend from Tucson and would like someone to do a pressure test on my intake to see if there are any leaks. I don't understand why I can't get more than 38psi of boost with all the performance parts I am running. I also wouldn't mind hitting a dyno if any are open this weekend. Any local members around this weekend? Anyways have a great weekend to all, Tom J.
Sorry , Man.
The one place that I have experience with out here is Chuck's Speed and RV Center.
They are only open Mon-Fri till 5:30 PM.
I did a quick search and had no luck on the Saddity Ares.
shoot, had I known a little earlier, I could have met up with you and tested it @ my house. I made a tool back when I had my 2nd gen that works trick.. Just out of curiosity though, are you sure the wastegate isn't set for 38psi? That'd be my first check for sure.
thanks,
Ken
thanks,
Ken
I don't seem to know anything anymore. I have been through more turbos than I can count but they all seem to have low boost. I don't know if I have a problem with my truck or what but I am not seeing the boost levels I should. Truck is extremely fast though and probably near 600 hp but the boost is not right and need some suggestions as to what I need to do. Thanks Tom J.
jgiachino
04-11-2008 08:41 PM
Lathe Guy
07-20-2007 01:54 PM
