dialbo stack settings
hi , just installed my dialbo stack , installed puck ran truck was good , inastalled programer on stack mod only one that came up on screen did not notice big difference , can i run one of the non stack tunes with the puck and get more power
Did you try one of the non-stack tunes yet? My truck runs awesome on the non-stack Extreme RKL tune. I'm scared to turn the Puck on with the non-stack tunes becuse they supposedly already add pressure and I think it may be too much.....
When you put it on the 90 hp with the extreme on no stack mode you increase the preesure a hole lot.becareful you could run your rail dry.and on a stock tranny your gonna kill it quick.
They don't offer the PUFFER tunes for the 06-07 units but I can tell you that the non-stack Extreme RKL tune doesn't need it. I can smoke out an intersection at will..... It's awesome!!!!
Right now I'm running the stack Extreme tune and the Puck on the low setting. Turning the puck on high is OK occasionally but leaving it that way all the time is not good for your injectors. I left the switch in the engine compartment so I keep my hands off of it.
Running the Non-stack Extreme tune feels much better and it doesn't pull my fuel pressure down like the stack tunes do. I'm not sure how that works especially when it feels like it's making more power... I'm going to switch back to that tune when I have 15 minutes to sit in the truck in this 100 degree heat......
cjones42
08-02-2007 02:18 PM
adventuris
07-02-2007 03:40 PM
UnrulyNFS
02-21-2007 08:21 AM
MoparRiggan
0
09-19-2005 08:19 PM
pcburnout
09-19-2005 07:00 PM
