Diablosport Causing Engine to Defuel
Old 07-15-2009, 10:54 PM
no_6_oh_no's Avatar
Originally Posted by Diesel87
What does it mean if your pump is out of phase?
The CP-3 has 3 pistons to pressurize the rail and it runs at half the crank speed. When a cylinder is at TDC and firing the pump needs to be hitting TDC with one of the pistons or you get a rattle due to gear drive noise from the compression in both places causing the gears to kick.
To phase the pump break the lock nut on the pump loose and rotate the engine 20-30 degrees then tighten the bolt and check for noise. Repeat as neede duntil the noise changes or disappears.
It should take only to phasing attempts to make a difference. If it doesn't you may have another problem.
Old 07-16-2009, 11:37 AM
Diesel87's Avatar
If the the pump is not out of phase and I try this, would it make my problem worse?
Old 07-16-2009, 11:42 AM
Diesel87's Avatar
This may be a stupid question, but if I am looking at the truck, would I turn it clockwise or counterclockwise?
Old 07-16-2009, 01:41 PM
no_6_oh_no's Avatar
Doesn't make a difference which wat you turn it. The idea is to change the phasing and that will happen either way. The easy way is loosen the pump and use the alternator to turn the engine backwards.
If it is phase and you get it out of phase, yes the noise will get worse, but, then you will know how to fix that.
Old 07-16-2009, 04:31 PM
Diesel87's Avatar
Thanks man I'll try it!
jstone44720
08-20-2012 08:39 PM
jaysie 59
07-16-2008 09:06 AM
H8GAS
22
02-15-2007 09:40 AM
GlennRMK
14
08-23-2005 03:18 PM
rico334
10-27-2004 06:49 PM
Quick Reply: Diablosport Causing Engine to Defuel
