Diablo Predator U7131
Just installed my Diablo stack. I was curious if you all are running the tune for the power puck, or if your just running the regular tune with the power puck. Right now I'm running the tune for the power puck I've tried both tow and performance, and with both I'm getting an idle surge. And then leaving the power puck switch in the stock position on both. I was curious to know if anyone else is having this problem? Should I run the programmer in its regular tune and not the power puck tune? Any help would be great. I don't think the idle surge will hurt it, so for now I will live with it and when I get more time I might try the regular programmer tunes.
I haven't tried anything but the Extreme RKL tunes, but the extreme tunes don't smoke as bad as the SmartyCR does on the lowest setting. The excessive smoke of the SmartyCR is the only reason I even tried something else, and so far I'm glad I did.
I'm sure the lower tunes stack up we'll as the Extreme RKL tune feels as strong, if not stronger then the SmartyCR does on #9.
kuhkuhkyle
13
10-08-2007 09:40 PM
MegaBOMB
04-20-2007 05:02 PM
kelley15
23
03-26-2007 03:52 PM
